Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Connecting rod shims
[Return to Forum]
sdc eastern ia
02-21-2013 14:56:46
69.63.4.10
Where can I purchase connecting rod shims. I have one rod that when installed and just snugged will seize the crank. I've battled this thing for two weeks now.
[Reply]   [No Email]
OLarry from MD
02-22-2013 14:54:25
97.73.64.148
 Re: Connecting rod shims in reply to sdc eastern ia, 02-21-2013 14:56:46
You have matched the numbers on both parts of the rod? I have seen several tractors wrong.In one case a fellow made one engine out of 2 and had to shim several in a s88. They ended up calling me after running the engine some.I found cap numbers that did not match any of the rods.i told them they had to remove all the shims and find the correct caps.Well the old unused parts had been put against the rear wall of an old building and the son had parked something in front and pushed them out the rear wall onto the ground in the cow pasture.
[Reply]  [No Email]
j williams
02-22-2013 14:16:03
69.161.81.52
Any chance the connecting rod has to be turned 180 degrees around on that and one other cylinder?
[Reply]  [No Email]
krm
02-22-2013 06:42:53
70.194.144.215
Try NAPA.
[Reply]  [No Email]
Tom Rowe-Drake
02-22-2013 06:40:52
108.12.194.206
Oliver 60 4 cyl. had 3 .002 steel shims on each side of the connecting rod brg cap when it was new. As the brg. wore down the maintenance proceedure was to remove one at a time from each side of the cap to keep the clearance in speck. This has worked well for over 60 + years. I use .002 brass shim stock and trace over an original. ( 3 per side when using std. brgs. ) You have to make shim hole go completely around the connecting rod bolt or it WILL fall out in time.
[Reply]  [No Email]
sdc eastern ia
02-22-2013 06:24:31
69.63.4.10
I'm just trying to remove posibilities 1 by 1 of why 1 rod when tightened will sieze the crank. I know which one it is as i put #2 into #5. Same thing happened. My machine shop says everything is fine and it left there place as it should. I must be doing something wrong. I've built motors that went 7 seconds and over 200 mph. This ain't my first rodeo. First tractor engine though.
[Reply]  [No Email]
ken l
02-22-2013 02:56:07
12.167.8.174
When I have an engine that originally had shims, I take the crank and rods to the machine shop and have the rods machined and bearings matched so shims aren"t needed
[Reply]  [No Email]
Don-Wi
02-21-2013 16:27:31
66.87.7.125
I guess so. He never mentored what he was working on so my mind went to 4 digit & newer. How thick are these shims? .001"? In that case some shim stock would work. Just make them what you need.
Donovan from Wisconsin
[Reply]  [No Email]
Don-Wi
02-21-2013 15:42:55
75.249.79.66
Did you mic the crank? Double check that the bearing is right? Never heard of shims for a connecting rod, and to be honest I'd be mad if I found out my engine shop did that.
If you don't have time to do it again, do it right the 1st time.
[Reply]  [No Email]
oliver90owner
02-21-2013 16:14:26
195.93.21.35
 Re: Connecting rod shims in reply to Don-Wi, 02-21-2013 15:42:55
Don-Wi,
Older tractors all used shims. Precision bearings were just not invented until ?.
These would be spun-in bearings or thick walled shells, often needing scraping to fit. Wear taken up by removing shims was a normal affair (until the journals got too oval!).
Now it is a bit naughty to be using shims with precision bearings...?
RAB
[Reply]  [No Email]
Dick L
02-21-2013 16:38:04
50.51.184.132
 Re: Connecting rod shims in reply to oliver90owner, 02-21-2013 16:14:26
Even Ole Chevys had shims under rod caps.
[Reply]  [No Email]
J. Schwiebert
02-21-2013 16:11:12
209.143.54.246
Don: Never heard of shims for a connecting rod, and to be honest I'd be mad if I found out my engine shop did that.
You are way too young. Early 77 & 88 Olivers had shims from the factory. The rods were machined when new with a shim pack in place. When the Oliver diesel came along the shim pacs left.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
