super 77 row crop
Anonymous-0
HAVING RUNNING ISSUES. REBUILT CARB MARVEL SCHEBLER TSX755. MINOR KIT. NO CHANGES. RAN GOOD THIS SUMMER AND FALL. HOOKED UP TO AUGER AND WOULD NOT STAY RUNNING. TUNED MOTOR. PLUGS, WIRES, CONDENSOR, POINTS, COIL AND FRESH GAS. STILL THE SAME ISSUES. WONT STAY RUNNING. ADJUSTED TIMING, GOT A LITTLE BETTER. BUT WONT STAY RUNNING. SOUNDS LIKE ITS RUNNNING OUT OF FUEL. NOT SURE IF I SHOULD GET A REMAN CARB, POSSIBLE ZENITH OR PULL CARB BACK APART. INSIDE OF CARB LOOKED CLEAN.
Fist place I would look is in the neck of the sediment bowl. Take one of the pipe plugs out of the front wheel, unhook the fuel line unscrew the sediment bowl, put plug in hole. Also if there are a few gallon of gas that run out it will help flush any dirt out of tank. Also check to see if your cap is vented. Start there, if no better and I will give you page 2. Also turn cap lock off.
I read your post and debated with myself weather to ask this or not because it sounds condesending but when is the last time you checked or changed your air filter. I've been in your shoes before and found myself chasing a problem I've created in my own head when I have not looked at the easy stuff first and later found that if I had I could have saved myself a lota time and $$. Not being an a$$ just asking. Rocky.
