77 hyd. Lift cultivators
John 37A
Working on a 77 that we just put cultivator lift on top of the trans. We aren't going to use the lift, but needed something to cover the hole. Anyway, after startup, I noticed an oil leak coming from 4 holes in the front of the lift assembly and leaking onto the input shaft. Is something supposed to go in the holes, or is the fluid level too high? I don't know much about this tractor. [/list]
Could they be oil holes for the belt pulley? This tractor doesn't have a pulley, but the one that the cultivator lift is off did have a pulley.
