TractorLinks.com
Show Parts for Model:
Re: 77 crank vs. super 77 crank
J. schwiebert
02-16-2013 10:02:31
All right, what are you trying to do? First of all a 77 crank has 2.000 crankpins. A super 77 crank has 2.250 crank pins. so each engine uses diferent connecting rods. Next question: Are both cranks for gas engines or diesel engines. If you need one for a diesel you need a diesel crank. You can put a diesel crank in a gas engine, but not the other way around.
J-J
02-16-2013 10:07:06
 Re: 77 crank vs. super 77 crank in reply to J. schwiebert, 02-16-2013 10:02:31
I have a super 77 gas engine that had a bad crank. well a ended up getting a 77 gas crank. I'm wanting to know if I can safely use the 77 crank in the super block. I realize I'll have to get the rods for the 77. This is going to be a parade show tractor.
J. Schwiebert
02-16-2013 14:27:53
 Re: 77 crank vs. super 77 crank in reply to J-J, 02-16-2013 10:07:06
What happened to your old crank? I would have thought by now someone would have asked about your old crank so they could off-set grind it for a stroker motor to go pull.
J-J
02-17-2013 07:32:24
 Re: 77 crank vs. super 77 crank in reply to J. Schwiebert, 02-16-2013 14:27:53
My old crank is cracked in 3 places.
dboll
02-16-2013 16:05:39
I could use a super crank to stroke , i'd just as soon use a wrn out one instead of wrecking a usable one unless the journals are blue. I have a ph.number of a guy that has a usable super crank.
Bryce
02-16-2013 17:40:30
 Re: 77 crank vs. super 77 crank in reply to dboll, 02-16-2013 16:05:39
Doug Ill be at Sigourney if you need a crank let me know. P.S. Reasonable.
dboll
02-17-2013 18:39:44
 Re: 77 crank vs. super 77 crank in reply to Bryce, 02-16-2013 17:40:30
I'll be there unless I am either too sick to attend or dead! I need one for the 77 I am working on. I just hate to use a good crank that someone else could use for their farm tractor. Please send me an email at dougboll@localnet.com with your phone # and we can talk about it.
