| Oliver, Cletrac, Co-op & Cockshutt Tractors Discussion Forum |
Topic: Re: 1600 charging system
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Oliver1600
02-13-2013 04:46:50
99.195.148.119
Thanks for your reply. one question why cant you use the existing wiring that went to the generator. If I look at the wiring diagram it would seem that the wiring is going to same place i just need to switch my batteries to negative ground? |
| J. Schwiebert
02-13-2013 09:17:43
209.143.54.246
Re: 1600 charging system in reply to Oliver1600, 02-13-2013 04:46:50
| One reason is the alternator has more output and the exisiting wire may not handle it. I would also use 14 gauge wires for the other wires. |
| Bob M
02-13-2013 08:34:21
74.67.191.60
| | Yes - as long as the existing wiring is in good shape there's no reason it cannot be reused. (The wiring on my 1600 was questionable which is why I ran new wires...) ---- To reuse the existing wiring: Connect the old generator ARM wire to the alternator output stud. Also connect together the BAT and GEN wires at the old regulator location. This will take care of the alternator-to-starter solenoid wiring. Connect the old generator FLD wire to the alternator #1 aux terminal. Then at the old regulator location, connect the FLD wire to the low side of the generator warning light. Be sure to connect the batteries NEGATIVE ground! ---- If wired right the generator warning light will burn when you turn the key on before starting the engine. The light should then go out after the engine is running. Note: You may need to goose the throttle a moment after startup "turn on" the alternator - this is normal. |
| OLarry from MD
02-13-2013 05:09:26
97.73.64.151
| Well you can just use the hot wire that went to the regulator and hook it to a single wire alternator.I have pictures of my conversion in the tractor photos section at left. |
| OLarry from MD
02-13-2013 05:19:24
97.73.64.151
Re: 1600 charging system in reply to OLarry from MD, 02-13-2013 05:09:26
| You do need to search for larry from md. |
| Oliver1600
02-13-2013 19:18:32
99.195.148.119
Re: 1600 charging system in reply to OLarry from MD, 02-13-2013 05:19:24
| Thanks everyone for your input and help, hope to get this project completed this weekend. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
