oliver part #s what are these parts?
jmducks1
BSRA-217 in oliver boxes i have 7, K-2222-D have 1 box, 1KS-101-A have 3 boxes, 107385-A I have 5, 113213 bag of 2 springs, K-2020 A have 1. IF someone could tell me what these are for and some kind of value for each would be great!
Ks-101A main bearings, standard size for an 88.
K-2222_D is a connector for a group 2 hydra-lectic, K-2020A is also a part for a hydraulic unit. I would need to check a parts book. The 113 213 in the Oliver parts system would have been parts for the HG ,OC-3 & early OC-4 tractors probably valve springs if they are small springs. The 107 number I would need to look up. The BS numbers are rod bearings for a 70 and not standard sizes. Also the 70 tractors took 3 right & 3 left rod bearings. If no one answers I can look it up but probably not till Wednesday. J.
113 212 is identified as a screw for the bumper spring in the governor in a OC 3 or a HG.
BSRA is .002" undersize main crankshaf Bearings for a model 70.
K-2020-A is special nut that screws into the hydraulic housing on a fleetline.  It accomidates the adjustable pressure screw.
K2222-D Is the male end of the hydra-electric wire for the remote cylinder.
107 385-A is the snapring that holds the bearing in place on a input shaft in a O/U or HPD.
