Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 550 power steering
J. Schwiebert
02-10-2013 04:58:18
You asked: "Is there a way to check the pressures"? Yes there is. When you rebuilt the pump what all did you do? You will need at least a 1000 PSI pressure gauge. Do you have a book? We did a Ford that had a minor fire and steers about the same. It is the same unit but uses an Eaton pump. I would check pump flow as well. Remember in hydraulics pressure is force, flow is speed. More questions? J.
Chief 83
02-11-2013 22:45:55
 Re: 550 power steering in reply to J. Schwiebert, 02-10-2013 04:58:18
There wasn"t much to the rebuild kit a couple seals and a gasket as I recall. I got the kits from a vintage Chevrolet parts guy. All the parts were right and went in great. If the flow of the pump is bad is the fix then a new pump? Going to have trouble I think finding a 1000 psi gauge. I will check with my machinist tomorrow. What should "good" pressure be? I do have a book and will re-read it.
