| Oliver, Cletrac, Co-op & Cockshutt Tractors Discussion Forum |
Topic: Oliver 77 clutch change ??????????
[Return to Forum]
| Author |
[Modern View]
| Showdown
02-07-2013 10:16:33
75.194.28.187
Does anyone known if I can change the clutch without pulling the engine, if so how is it done? Thanks for any help. |
| chucksoliver77
02-07-2013 20:06:50
71.0.111.175
Re: Oliver 77 clutch change ?????????? in reply to Doug A. Mn, 02-07-2013 10:16:33
| how big is your engine and how much power does it make? that will tell us what you need for a clutch. Chuck |
| Showdown
02-07-2013 19:18:28
75.194.238.117
Re: Oliver 77 clutch change ?????????? in reply to Showdown, 02-07-2013 10:16:33
| I did remove the pto. The clutch and press. plate are stock. I'am trying to get and idea of what to replace it with if it does fail in the future. If I pull the bell housing off can I see the amount of wear left on it? Where do I get a replacement? |
| Showdown
02-07-2013 14:30:29
75.194.238.117
| What do I use, where do I get a new clutch disc if needed. I do tractor pull this 77. Thanks... |
| J.Wondergem
02-07-2013 16:14:13
70.194.4.159
Re: Oliver 77 clutch change ?????????? in reply to Showdown, 02-07-2013 14:30:29
I'd go to a place that rebuild truck clutches and see about a ceramic clutch disk, and a new pressure plate. |
| Showdown
02-07-2013 14:22:15
75.194.238.117
| Mine doesn't have the belt pulley. Does the bell housing come right out off the tractor when unbolted, does this then let you remove press. plate and replace clutch if needed? Thanks. |
| K. Schwiebert
02-07-2013 18:44:14
209.143.54.246
Re: Oliver 77 clutch change ?????????? in reply to Showdown, 02-07-2013 14:22:15
| Yes. Since you pull it do you have a PTO or did you shed it remove the weight? Which clutch do you have? You can put a bigger clutch that standard in there. |
| Schim
02-07-2013 12:36:04
12.207.74.3
| Do you have a belt pulley on it? If so you more than likely will have to pull the motor.If you dont just take the pto clutch housing off, unbolt the pto clutches, and pull the long shaft out. Dont have to pull it out all the way unless you want to look at it. Then take the sheet metal off, unhook the coupler to the trans, and unbolt the bell housing and pull it out. |
| J. Schwiebert
02-07-2013 13:33:41
209.143.54.246
Re: Oliver 77 clutch change ?????????? in reply to Schim, 02-07-2013 12:36:04
| You fold the panel over, take the pulley housing off and let the engine in. We used to change 2 a day out in the country if the farmer would agree to remove the sheet metal and the fuel tank |
| J. schwiebert
02-07-2013 12:31:29
209.143.54.246
| Yes, we used to do them all the time. Kep point remove the long PTO shaft first. Does your tractor have the belt pulley drive housing? |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
