Question for Semper Fi 88 Darton sleeves
PCH
Hello you had posted that Darton makes a sleeve that would drop into factory 310 block, increasing bore size to 4.060. Where do I find these sleeves? With these sleeves do you know what the deck height is? Thanks
The deck height will not change if you put the Darton sleeves in a stock block. You can also run a stock head gasket with them. You can get these sleeves by contacting Darton and they will probably ask you to send a stock one to them and they will make however many you want. I'm not sure on an exact price but they are ductile iron and pretty much indestructible.
Pic of Darton liner
