Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 60 Oliver row crop
oliver90owner
01-24-2013 14:07:29
Is there a reason for the over-sized bearings (mains are fairly common) or do you mean under-sized?
LaRay Vanderpool
01-24-2013 14:26:51
 Re: 60 Oliver row crop in reply to oliver90owner, 01-24-2013 14:07:29
I had to turn the crank, main bearings and rod bearings .010. Looking for bearings, thank you.
J. Schwiebert
01-24-2013 19:17:36
 Re: 60 Oliver row crop in reply to LaRay Vanderpool, 01-24-2013 14:26:51
You need 10 under bearings.When a crank is ground the bearings need to be undersize because the mains and crank pins are now undersize. The rod bearings are the same as for a 66 or 77 Fleetline tractor. For the main bearing set you will need to have a couple of oil holes relocated. Now the thrust on a 60 only has a flange on one of the shells. . There are several ways you can do this. Wait till tomorrow and I will get you both the Clevite and the F-M bearing numbers. Any other questions? We have a 60 engine apart at work right now so I can look if I need to.
laray vanderpool
01-25-2013 11:12:28
 Re: 60 Oliver row crop in reply to J. Schwiebert, 01-24-2013 19:17:36
thank you for the info. I wood like any info. you can give me. how do you tell what engine you have, there are cast numbers 160120e ,D158, ser. 624620
J. Schwiebert
01-26-2013 18:56:16
 Re: 60 Oliver row crop in reply to laray vanderpool, 01-25-2013 11:12:28
How can I contact you?
laray vanderpool
01-27-2013 06:53:09
 Re: 60 Oliver row crop in reply to J. Schwiebert, 01-26-2013 18:56:16
my cell # is 517-462-1538. Would really appreciate it.
