Anonymous-0
I have a 1650D Oliver with a Stanadyne Injector Pump, Model DBGFC633-21DH. The only problem I'm having with it is the shut off mechanism. All exterior parts are tight and the shaft going into the injector pump is working when you pull the shut off cable. Is this fixable without sending it off and having the whole pump rebuilt or will it have to be rebuilt. I had several parts places say this type pump cant be rebuilt. Also im rebuilding the steering cylinder. I got most of the "0" rings from a hydralic shop except for what I call a cup seal. They gave me an "0" ring in place of it to go around the bottom of the pinion gear inside the cylinder. Does anyone know for sure this will work or will it leak fluid. Do they make a kit that I can purchase somewhere. I also need a check valve spring that goes on the piston inside the steering cylinder. Any information on these items will be greatly appreciated. Thanks in advance.
