TractorLinks.com
Show Parts for Model:
Re: best way to add cu. in. to 310 oliver gas
6pack
01-22-2013 10:17:27
offset grind crank with early 77 rods... I have a set for $100... Find a off the shelf car piston of 4.00" -4.03" then bush down the wrist pin... Could end up with a 4" bore and 4.75" stroke reasonably, will have to take a little of cam...
Also have 4.125" pistons from a 320 that will work with the 77 rods, but will have to bore the block and put sleeves in... Might as well go bigger if you end up boring block...
I have a set of John Deere 404 sleeves.. Still have cross hatch in them... They are 4.25 but can be made bigger..... Once again have to bore block
