chucksoliver77
I'm going to change the trans and hydraulic oils in my 550. I'm thinking universal trans/hydraulic for both. What is recommended? thanks in advance, Chuck
Hyd run 30 wt motor oil, rear end 80_90 wt. When you drain
the rear end get all three plugs to make sure you get all the old
oil out
I use 80-90 oil in transmission. I wouldn't go any thinner or I would get more leaks. I use universal trans/hyd fluid in the hydraulics. Very cold MN climate. Have fun!
