Josh I would give Larry Harsin a call. I've bought 3 tractors from him and he is one of the best. I'm sure he'd have the parts or give you some dimenstions.
http://morpheweb-server2.com/harsin/main.html
The 3-9/16 are M & W pistons. You might want to go with 3-5/8 which are more available. The 3-9/16 are an odd ( M & w naturally) piston size to start with. Compression distance is the same as the normal Oliver Pistons. I can look it up
