TractorLinks.com
Show Parts for Model:
oliver hg
PHILIP JOHNSON
01-14-2013 16:53:26
i to am working on hg oliver i need to know wires on the mag. it is a model x, i know #1 is at the window,what is the # across and what is the # below the 1 thanks for help
Chile43
01-15-2013 03:40:56
 Re: oliver hg in reply to PHILIP JOHNSON, 01-14-2013 16:53:26
No.1 spark plug cable plugs in distributor cap in the upper right hand corner, cables 2-4-3 follow in clockwise order
J. Schwiebert
01-14-2013 17:20:14
Always remember that #4 will be straight across from #1 on any 4 cylinder in line engine. I would need to look but if you put say #2 next and then #3 across from it and it misses turn those 2 around.
oliver90owner
01-15-2013 00:59:38
 Re: oliver hg in reply to J. Schwiebert, 01-14-2013 17:20:14
Also, there is always the risk that the mag has been fitted 180 degrees out, and other issues with the mag distributor if the speed reducer section has been tampered with (I am thinking this mag is driven at crankshaft speed?).
PHILIP JOHNSON
01-14-2013 17:39:27
thank for the help ! well make up wires ,maybe try fire up tommrow!
