Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: compatible rear ends to a 2255
2255tr
01-11-2013 20:31:35
The Moline G1355, White 2270,and low serial numbered White 2-150 did use the same shafts,1/3,2/5,4/6 transmission gears, planetaries and differential final drives as an Oliver 2255.
The only difference was in the High range and Low range gear sets.Those pairs of gears had a lower ratio and were changed due to the higher rated rpm of the Caterpilar engine.
The later Serial numbered White 2-150 also used different 2/5 and 4/6 gear sets.They were different gear tooth counts but close in actual ratio to the earlier serial numbers.
