Anonymous-0
Thanks for the advice on the relief valve. Now to clean it do I just remove the cap and related parts, or should I also loosen the large hex nut and remove the whole thing from tractor? Couldn't find a picture on AGCO parts site, so still not quite sure how everything works. Thanks.
I had a problem with my 2-70 hydraulic relief valve also. The cure for me was to tighten up the internal adjusting nut that had worked loose.
