Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Running a mower-conditioner on 88
J. Schwiebert
01-09-2013 18:27:23
First of all find out what the recommended pressure is for operating the mower. You will also need to know the capacity of the 2 one way cylinders. This is to insure you have enough oil in the reservoir. Do you have an operators manual for the 88? You will need to convert the LEFT side to operate the one way cylinders and the right side for the double acting cylinder.This should be covered in the operators manual You will also need what Oliver called a "Momentary restrictor" so that you can build pressure to knock the ball off the seat to make it work as a single acting cylinder.I have another suggestion but you will need your check book.
Copyright © 1997-2015 Yesterday's Tractor Co.
