Power Beyond 1855
Jim Meade
Does anyone have any experience using the Fitting - Power Beyond - 5/8 X 5/8 Tube X 1/2 NPTF
30-3045994. Use it to replace the normal TEE.
I assume the other option is to cut the high pressure line and insert a TEE.
The Poewr Beyond fitting lists at $60.
That looks easier than what I had to make. I had a local hyd hose maker make me a new hose and T setup so I could still use the regular T. Think I had around $50-75 bucks in the hose and fittings.
The 4 way lets you use existing Oliver lines, it would seem to me. Adding a T requires you to cut the high pressure line, doesn't it?
