Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: timming on oliver h-g cle-trac
[Return to Forum]
bobs old iron
01-06-2013 22:51:15
97.122.248.55
ok, been working on and off for a time,,can't get timming right, other club members trying to help,, is their any one/place that i can get the info/pics on the firing order on my oliver cle-trac h-g,,, thanks bob
[Reply]   [No Email]
bobs old iron
01-08-2013 14:11:51
97.122.253.231
Re: timming on oliver h-g cle-trac in reply to bobs old iron, 01-06-2013 22:51:15
thanks everyone for replys, will pass on to members helping me, will keep checking if anyone think/has more ideas..bob
  [Reply]  [No Email]
oliver90owner
01-08-2013 02:15:18
195.93.21.35
As a starting point (apologise for the puns) I always set the timing with the piston just beyond TDC when the mag impulse trips. It will run no bother at that and you don't get a bad arm/shoulder from kick-backs (mine are all hand cranked). A xenon light, once the engine is running OK, can be used to fine tune the timing, if required.
  [Reply]  [No Email]
Hank
01-07-2013 15:54:45
24.110.23.134
Correct mag timing is 14 degrees or 1 15/16 inches before top dead center, which is the same as "SPK" mark on the flywheel. Before installing mag make sure rotor is timed to drive gear. Turn drive coupling in opposite direction of normal rotation until white line on rotor shows in center of distributor cap window If flywheel "SPK" mark is in center of bellhousing timing hole, mag coupling should align with hole.
  [Reply]  [No Email]
Hank
01-07-2013 15:59:56
24.110.23.134
Re: timming on oliver h-g cle-trac in reply to Hank, 01-07-2013 15:54:45
last line should have read magneto coupling should align with DRIVE not hole. sorry for type o
  [Reply]  [No Email]
dup44
01-07-2013 14:15:31
24.110.23.134
Does your hg have a mag? If so is it a model C or model X mag?
  [Reply]  [No Email]
bobs old iron
01-08-2013 14:09:23
97.122.253.231
Re: timming on oliver h-g cle-trac in reply to dup44, 01-07-2013 14:15:31
not sure righjt now, it"s out in country at members house..
  [Reply]  [No Email]
OLarry from MD
01-07-2013 06:04:30
97.73.64.144
Fireing order is 1243 and front is number 1, but it will run with the rear as number one.
  [Reply]  [No Email]
bobs ol iron
01-07-2013 09:44:49
97.122.248.55
Re: timming on oliver h-g cle-trac in reply to OLarry from MD, 01-07-2013 06:04:30
thanks larry for reply, should have been more specific,,, try to get pics/info as what/where the timmng marks, [pins] would be in reference to cam and dist postition, seems like we can"t get markings alined..without tearning into front end to see if gears have been messed with...bob
  [Reply]  [No Email]
OLarry from MD
01-07-2013 14:46:28
97.73.64.152
Re: timming on oliver h-g cle-trac in reply to bobs ol iron, 01-07-2013 09:44:49
If the lugs on the mag drive are in the wrong place when at tdc, then you don't have enough twist on the mag to get timeing right.I think the lugs need to be crossways.Someone help me out if wrong.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
