Show Parts for Model:
Re: engine transplant 1750
01-05-2013 17:10:51
Probably would have cost less and given you a better tractor if you'd have found an 1850 diesel that was beat in to the ground,used the frame from that and a Perkins out of a low hour combine.
01-05-2013 18:04:08
 Re: engine transplant 1750 in reply to rrlund, 01-05-2013 17:10:51
I did bought a 1850 for the tub, frount end, bellhousing and a few other parts. The costly stuff is hte flywheel to bolt to a cummins, hub and clutch. But I know it is done right as well. The $2000 is the Wide frount end to the tractor everything i needed minus the engine.
01-06-2013 07:35:02
 Re: engine transplant 1750 in reply to mlansing7836, 01-05-2013 18:04:08
I'd forget about the Cummins. Was any part of the 354 Perkins in the 1850 that you bought? If you have that engine to rob the parts from,all you need is a 354 Perkins from one of many different makes and models of Massey or White combine.
