Is this an Oliver HG or OC3
t hiben
New User
The reason I ask is the steering levers are differant than what you normaly see and the rear fenders are like I've not seen either,the serial tag is under the lift brackets and is hard to see, any in put would be great ...thanks
Just a couple observations: 1. I beleive all of the OC-3 tractors had the newer front idler wheels that were solid (ie. did not have the round holes in the wheel disks.) 2. This apprears to be an HG-31. This is the narrow gage tracor. Other gages were the 42, 60 and 63. Only the 31 gage had the steering levers offset to the outside as this tractor has. Also, all of the 31 gage tractors I have seen have had the fenders covering the tracks. Most of the 31 gage tractors I have seen had the 6 inch tractors. This tractor seems to have 8 or 10 inch tracks.
On the left side of the block, the model of the engine and the engine serial number will be stamped. What is it?
