1650 power steering hoses - new
jim_uny
new years eve i broke power steering hose on 1650 front end loader tractor. use it to feed cows daily. replaced at napa by cutting ends replacing with two compression fittings. leaked went back and tightened. aok. i want back set. can you buy them new ? top ones are tight tolerance. napa did not have fittings. added conduit to protect hoses. have replaced all 4 but i want to back up. with deep snow seems to put pressure on front tires with heavy baleage.
So they blew out at the fittings?
I'd replace with flexible stainless lines before considering new rigid steel lines from AGCO, even if they're available at this point.
As of two years ago, I was able to get a new set from AGCO for my 1650. It has the newer Eaton style motor, however.
