310 Waukesha
Anonymous-0
Can a 310 Waukesha gas block and crank be used to build a diesel with a diesel cyl. Head and front cover assy.?
Well, I say probably not. Gas cranks are not usually hardened the same as diesels, but as Tramway Guy says .... let's see other responses ...
Let me ask you this: What is the block casting number? What do you want to build? Do you have the block? If that answer is yes, does the block use 9/16 or 5/8 inch bolts
