TractorLinks.com
Show Parts for Model:
Re: Oliver 77
jordan hackman
01-02-2013 10:52:36
you can add a pump to it fairly easily. we did the same with our 88 standard. however when we did the 88 it had just a cover and we found out that the shifter is a different design between a plate and a hydraulic pump and i am not sure if there is a difference between a rollamatic and a hydraulic pump so stick with the shifter that came with the pump. to install it you need to take the pto clutch shaft out then add the pump to the tractor then put the shaft back in. wish you luck.
chucksoliver77
01-02-2013 12:17:52
 Re: Oliver 77 in reply to jordan hackman, 01-02-2013 10:52:36
Quoting Removed, click Modern View to see Jordan, the shifter is the same, just the shifter lever socket or shifter mount is different. chuck
