perkins injectors
Need more inforation> First off you did not say what model Perkins you are working on. Second you did not say which injectors you have now. You also did not ay what model pump you have or where it is set. Now I have abou a 10 year old nozzle catalog and there are close to 20 different tips in there for the 354 Perkins engines alone.
6-354t dot 4 i gess you call it it is out of a massey combine, i want turn up the pump and put a bigger turbo on it, but haveing truble finding a front pully with the rubber in it, im going to put it in a 1 ton crewcab truck will probley never pull much thanks
