Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: 1650 diesel oil pump pressure relief valve
[Show Entire Topic]  [Return to Forum]
J. Schwiebert
12-27-2012 15:53:37
209.143.33.150
Let me ask you this: What oil pressure do you have when the engine is cold? When say it has been at operating temperature say for 2-3 hours? Have you had the pump apart and measured the clearance. Are you coating the pump internally with oil are how are you sealing the pump?
[Reply]   [No Email]
J. Schwiebert
12-28-2012 09:56:01
209.143.33.150
 Re: 1650 diesel oil pump pressure relief valve in reply to J. Schwiebert, 12-27-2012 15:53:37
I would rig of a leak detector and see where you are loosing the pressure. If you are close to 40 pounds cold a new spring is not going to help you much. I need to do some digging, but the oil pumps on the turbocharged engines used a different spring and that oo4 clearance I think is on the high side.How about a phone number? We can discuss it in more detail. J.
[Reply]  [No Email]
jacks
12-27-2012 16:21:30
70.192.195.93
I am replacing the main and rod bearings due to the previous owner operating the tractor with the lift pump leaking diesel into the crankcase. I had an oil analysis done which indicated excessive diesel fuel and bearing material in the oil. After replacing the lift pump, the oil stayed clean, but the pressure was too low. Oil pressure would initially be at about 40 psi in cold weather, but would decrease to only 5-7 psi at 1500 rpm with the engine hot. The relief spring in the pump measures shorter than the spec, I am trying to find a new one. I already replaced the main oil pressure relief spring on the front of the block. The gears in the pump have only .004 clearance to the body.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
