TractorLinks.com
Show Parts for Model:
Re: 2-70 just idles
Dieseltech
12-27-2012 11:04:31
Try running engine with pump timing cover loose so fuel can leak out of housing. If it will accelerate ok then pump needs serviced as weight retainer ring is failing, small bits are plugging return fitting causing high housing pressure. This will cause the trouble you have, or even die, then restart after awhile then die again.
