TractorLinks.com
Show Parts for Model:
Re: 2-105 vs 2-135 fuel consumption
rrlund
12-23-2012 12:17:30
Ya,the baler runs 540 on the PTO at 1700 RPMs on the engine of the 2-135. Where did you get the results? Do they tell gpm at 1700?
rrlund
12-23-2012 13:05:06
 Re: 2-105 vs 2-135 fuel consumption in reply to rrlund, 12-23-2012 12:17:30
Never mind. I found it under Test on Tractor Data.
Anybody know fuel use at 1700 RPM with a moderate load though?
e
12-23-2012 14:15:17
 Re: 2-105 vs 2-135 fuel consumption in reply to rrlund, 12-23-2012 13:05:06
Best approximation would be to look at the drawbar pull section at at 50% load (64 hp) and 1561 rpm, it used 5.1 gph. Now if you look at a 2-105, at pto speed (2300rpm) and 71hp, it consumes 5.3 gph.
That's not a perfect comparison because we are comparing a drawbar test to PTO test which gives an slight unfair advantage to the 2-105 (less driveline losses through the PTO vs the transmission).
Bottom line, you are not going to save a whole lot if anything by buying a 2-105.
And if you are worried about wearing out a clutch, put in a kevlar one from Southbend. Best bailing clutch out there in my opinion.
Larry NEIL
12-23-2012 21:06:34
 Re: 2-105 vs 2-135 fuel consumption in reply to e, 12-23-2012 14:15:17
I think you need that 105 in your stable Randy!!
rrlund
12-25-2012 07:02:19
 Re: 2-105 vs 2-135 fuel consumption in reply to Larry NEIL, 12-23-2012 21:06:34
Ya,trying to justify it!
