2255 clutch
SteveGr
What if anything has to done to put a 2-180 clutch in to a 2255. Does the input shaft have to be changed? I am changing the clutch in one and is just wondering. Thanks in advance.
I PUT ONE IN MY PULLING TRACTOR CAT V8 2255 2-180 CLUTCH IT BOLTED RIGHT IN , WORKS GREAT IT DOUBLED THE CLUTCH SURFACE BY 2
You will need a throwout bearing holder from a factory equipped dual disc clutch white tractor (2-180,4-180,4-210,4-225) On your 3spd you will need to remove about 1/2" off the tube the throw out bearing holder rides on.It will make room for the second disc to sit on the input shaft splines.
