880 lube pump
Do you mean the transmission lube pump? If so, the answer is NO. They were available as a field installation package. Also remember the first year of 880 production they used a spur gear transmission so no need to pressure lube the top shaft. The pump is driven by the transmission countershaft. There were 2 versions of these kits. You had to split the tractor to install the later one. A tractor with a pump will have a filter mounted to the dash on the right side.
We have 2 880's one is a 60 with this filter on the side and a 61without this filter/pump setup both have powerboosters. Is there any benefit to have this pump?
The pump was installed to lower the chances of having transmission problems on the helical 880's. Not very many standards had the pump added, so it's not to often you see them up here.
You need to understand how a constant mesh transmission works. When you use any of the high range gears the speed of the low range imput gear runs faster than what the speed of the imput shaft is. I am not going to calculate the speeds for you but I did an article for the HPOCA magazine that pointed that out for the 1800 transmissions. The same thing will occur in the 880 transmission. Is the tractor used for farming? If so when you have the transmiison in neutral with the engine running, place the transmission in the low range neutral. I alway though the 880 without a power Booster and a pump was a good trouble free 60 horsepower tractor. Now it would be good just for spreading fertilizer, it would be good for running an auger, but the hydraulic system does not have the capacity to lift one.
Thanks for that info j.schwiebert it is used as a loader tractor around an acerage with some mowing and disking. The one with the pump in it is a parts tractor so its not used.your right there isnt much hydraulic power it just about isnt enough for the loader and anything heavy it wont lift
