chucksoliver77
this little tractor came home with me yesterday. it is a 1959 one owner tractor that has 3600 hours on the original working hour meter. the only problems I've found so far is the lever for the remote valve is froze, the gen doesn't charge and a couple oil leaks. I'm sure there will be more as i dig into it. chuck
Chuck, finding that tractor for that $...I think you should have run out and bought some lottery tickes. This must be your lucky day!!
Nice find!
he Ken how are you doing? no i bought at an estate sale in new york. also bought a super 66 wide front that Doug is getting. Both tractors were priced very cheap. hope you and your family have a Merry Christmas, Chuck
Chuck, don't sweat the mechanical stuff, your tractor looks really straight. The typical wear points on the frame, steering, draw bar, lift hitch and floor boards tell me that the 3600 hours on the tac is pretty accurate. If I would critique the tractor, I would upgrade the exhaust to spec asap. I believe the exhaust had a 60 degree bend to act as a rain cap and finially that corosion on the front wheel tire stem hole needs immediate attention. Other than that, I think after it is steamed and detailed, I would have a rought time justifying any re-paints. Nice looking tractor, it has a good home.
WP Fleming, thanks for your comments, however I'm going to go through the tractor and refinish to it's original beauty. chuck
