Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Need a center link
oliverkid
12-17-2012 18:45:11
Ok, im putting a different hydra power in it first. Ill have to make a run back down after I get the old girl back together. Thanks for the info.
J. Schwiebert
12-18-2012 01:45:59
 Re: Need a center link in reply to oliverkid, 12-17-2012 18:45:11
Why are you putting a different hydra-power in? What is the problem with the one that is in there?
oliverkid
12-18-2012 04:22:07
 Re: Need a center link in reply to J. Schwiebert, 12-18-2012 01:45:59
It is a first generation with no updates to it. Plus I found a working one out of a 1650 for $600. I would have more than that in parts just to update and rebuild mine.
e
12-18-2012 07:08:17
 Re: Need a center link in reply to oliverkid, 12-18-2012 04:22:07
You'll have more tied up in that 1600 than it's worth before you know it. A good complete runner is only worth about $2500. Why not take apart the hydra power you have first to find out what's wrong before spending $600. It won't cost you anything and you need to pull it anyways.
And if you don't need a top link right away, just keep tabs on ebay. Except for the U, you can buy the rest brand new and complete for $180. Call rock valley tractor parts and see what they get for one. You can dicker with those guys...and use the fact that new parts are $180 to negotiate a better price for used.
J. Schwiebert
12-18-2012 06:11:02
FYI. There are 3 distint versions of the Hydra-power. I would pull the cover off and check into the condition of the splines and the low range output gear. We did a 1650 gas for a man last winter and those splines were almost sharp enough to shave with.Also the heady duty replacement gear and shaft are NLA. There are also updates to those covers. More questions?
