1650 hyd pump question
A 1755 is an axial piston pump, your 1650 pump is just a plain jane gear pump. Also axial piston pumps need an external means of filling. Yes the 1755 pump is on the outsie. Your long uses a gear pump. The 1755 is a closed center system, your Long and 1650 are open center systems.
I am just putting it back together as I have time.Did not remember having to fill them with hyd. oil,but its been a long time since I changed one.Thanks for the info.As usual I'm amazed how much you know J.
