Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Oliver 77 Transmission Input Shaft Removal
J. Schwiebert
12-17-2012 04:09:24
The front bearing stays on the shaft, the rear bearing stays in the transmission case. Hold it in place with the Cresent wrench. As soon as the shaft clears the rear bearing and the front bearing is out of the case you tilt the shaft to the side and slide it forward. If you have questions answer with a phone number.
12-18-2012 17:22:08
 Re: Oliver 77 Transmission Input Shaft Removal in reply to J. Schwiebert, 12-17-2012 04:09:24
Ok I'm back at it again. My front bearing will not move, the shaft just drives on through it. I tried driving it back to get a lock ring in the slot and drive the bearing out with the lock ring on, however, I haven't figured a way to get the lock ring on in the middle of the shaft. 316-249-5855. Thanks
12-17-2012 20:49:45
Thanks again, I will try that when I get rid of this cold.
