oliver 88 clutch
Gary in W I
New User
Ihave an oliver88 we are trying to put a clutch in, and we"re having trouble to get enough free-play to be able to shift it. We"ve done everything according to the book, wondering if anyone else had that problem and can give me any ideas of what to do. It"s an 11 inch clutch. Thanks!
I read this that the clutch does not release. Is this an older 88 with the bushing type pilot bearing or a later 88 with the ball type pilot bearing? No matter which type did you change it? Next question how much free travel do you have the way you have it adjusted now?
Been there had same problem. Problem was wrong pressure plate and disc. Fingers were hitting rivets on dics. I took it all apart again to figure it out. Yes dealer sent proper parts for free then.
