1850 P/S Hydraulics
LucasD
Finally got around to testing the hydraulic pressure on the flow divider and outlets. I have 1300psi at the flow divider, and 2200psi at the outlets.
Tractor will barely steer when sitting still, but lifts implements fine. What is the next step?
Lucas
Jack the front end up so the wheels do not touch the ground. Have the pressure gauge in the flow divider. See what kind of pressures you have when you turn the wheels.
What's the history here. Has anybody changed any steering lines on it? I had a hose made for mine a few years ago. The guy at the auto parts store put the wrong die in the hose crimper and crushed the inside of the tube. Couldn't steer it for anything.
