This is a Case 4-14 hydraulic lift plow that some believe was built by Oliver, I know that oliver did build plows for Case but Im not sure if this plow is oliver built, can someone clarify?
that is a case plow. case started buying oliver plows in the mid to late 70's, ford did the same thing and maybe a few other companies.
This is a Case plow. I own a Model A 4-14 (Green axle) like this one and a late model (one of the last Case built) Case 4-16 semi-mounted plows. Check the numbers but don't give it away. These are VERY good plows when set right.
