Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 77 flywheel
[Return to Forum]
30.5s
12-06-2012 20:17:18
166.181.3.250
ok, I bought a 77 this weekend that is already set up for pulling, motor bored & stroked. was told it has a diesel flywheel and starter, what is the advantage of this set up?
[Reply]   [No Email]
chucksoliver77
12-09-2012 13:13:24
71.0.111.175
 Re: 77 flywheel in reply to Rabbitchoker, 12-06-2012 20:17:18
it's hard to believe that still has a stock head on it with all the other engine work done, yes do both the intake and exhaust valves and then open the ports, but don't go to far and hit water. an engine that size could use even bigger valves, maybe you should take it to a good machine shop and see how big of valves can be installed. chuck
[Reply]  [No Email]
30.5s
12-09-2012 16:48:09
166.181.3.130
 Re: 77 flywheel in reply to chucksoliver77, 12-09-2012 13:13:24
yeah i was thinking of bigger valves anyway but first need to fix bottom end. had piston come apart another cracked, one wrist pin turned into a full floating one, it has cast sleeves now and gonna make new outta steel and use a nice full skirt piston. i think it had a 770 head on it at one time when talking with the owner.
[Reply]  [No Email]
chucksoliver77
12-07-2012 14:44:20
71.0.111.175
 Re: 77 flywheel in reply to 30.5s, 12-06-2012 20:17:18
30.5, if you don't already have the 770 head, put the cost of the 770 head in the 77 head and you will be ahead of the game. you can put 880 valves in your 77 head and there is enough meat in the seats to just fit the 880 valves in and port or have someone port and polish it for you. i put 880 valves in my head this way about 30 years ago with good results. do you know the bore and stroke? can you post a pic. of the carb side of the engine? chuck
This post was edited by chucksoliver77 at 14:51:17 12/07/12 3 times.
[Reply]  [No Email]
30.5s
12-09-2012 11:56:09
166.181.3.89
 Re: 77 flywheel in reply to chucksoliver77, 12-07-2012 14:44:20
did you put both intake and exhaust in or just intakes? was told the crank was stroked an inch, with some rough measuring its 4.125 bore and 5.25 stroke. I forgot to take a pic of carb side but someone has done a little grinding on the outside of the block.
[Reply]  [No Email]
chucksoliver77
12-06-2012 20:25:54
71.0.111.175
30.5s, the flywheel is the same as a gas, the ring gear is different. they probably used the diesel starter for the extra cranking power. chuck
[Reply]  [No Email]
30.5s
12-07-2012 13:41:16
204.54.154.68
 Re: 77 flywheel in reply to chucksoliver77, 12-06-2012 20:25:54
thanks chuck, is there much difference between a 77 and 770 head, (valve size, cumbustion chamber)was thinking of pulling in div. 3 but dont know if 770 head is legal or worth the time and money to get one.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
