| Oliver, Cletrac, Co-op & Cockshutt Tractors Discussion Forum |
Topic: Re: 1755 Hydraulic Leak
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| buzzinduzzin
12-04-2012 03:07:38
66.220.92.37
is the rear end oil level now too full? if you are confident that the p.t.o. is the culprit it will need to be removed & rebuilt. There are a few other places where hyd. oil can get into the rear end. |
| UP Oliver
12-04-2012 05:49:37
208.68.25.63
Re: 1755 Hydraulic Leak in reply to buzzinduzzin, 12-04-2012 03:07:38
| | I need to check the rear end level, but last time I checked it the level was above where it was supposed to be. As far as my confidence on what the problem is, that is my question. Is there any other test or check that needs to be done to be sure? Thanks. |
| Wrenchbender
12-04-2012 15:02:03
96.60.185.66
Re: 1755 Hydraulic Leak in reply to UP Oliver, 12-04-2012 05:49:37
| 99.9% probability that it's the O-rings in the PTO. WB<><. |
| UP Oliver
12-04-2012 20:35:51
68.70.134.91
Re: 1755 Hydraulic Leak in reply to Wrenchbender, 12-04-2012 15:02:03
| | Any idea where I can get the parts, or the kit I need? Thanks. |
| Bradwi
12-05-2012 19:54:08
70.226.164.157
Re: 1755 Hydraulic Leak in reply to UP Oliver, 12-04-2012 20:35:51
| Call jerry at ag parts first 1-866-264-9720,you need a quad ring kit for the pto.There are also some lip seals in there off the top of my head i think there are three one for the range selector rod (if it is a two speed pto)Then one on the topshaft and one on the lower shaft.As far as the project it self I did our 1755 in an afternoon.But i had previously power washed the tractor so add an hour to do that if needed.As was stated before pull the long pto to flywheel shaft out (a good long 1/2 inch bolt is needed to use as a puller),drain the rear end,unhook the pressure and return lines and remove from the rear housing.When I take these out I have found it helpful to cut the heads off of two 10" long 1/2" bolts and wind them into the two lower big holes on each side of the pto.it works nice to slide it away from the tractor without having it drop ,although it takes a little careful wiggling to get it out because the internal casting on the pto unit is just tall enough that it hooks the top of the rear end housing.An overhead chainfall is ideal if available otherwise....watch your toes!The rest is disassemble then re assemble nothing too tricky ,except the manual calls for a compressor tool to press the spring in there to unseat a snap ring.I welded one up finally but if you are careful a short piece of chain and a bar can get it done.I'm sure i may be forgetting something,but thats what i recall.hope this helps |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
