TractorLinks.com
Show Parts for Model:
Re: Cockshutt 570 DIesel, Injection pump problems
RussUPpswrd
12-03-2012 15:36:19
Next time you walk up to a half dead diesel dinosaur make sure you treat it early to a fully charged battery system and clean connections to spin it with some gusto. Also make the engine think it is mid-August. Tent the tractor, thoroughly heat soak the engine, diesel injector pump and distributed lines. A kerosene space heater can to this job as long as you set the distance to prevent accidental grease/diesel fire. This would be one way to go if the pump plunger has not already gone bad.
Mikefromcny
12-03-2012 18:47:51
 Re: Cockshutt 570 DIesel, Injection pump problems in reply to RussUPpswrd, 12-03-2012 15:36:19
Thanks for the info guys. Those pictures were taken a week ago when I reinstalled the wheel. It was about 45F and rainy so I figured it couldnt be too bad since nothing was frozen. I bought a case forklift with a 207D that ran after not starting in 10 years off the same property, it was about 250 yards from the cockshutt. Only pump problem I had (roosamaster) was the governor ring failing after a few hours.
Does anyone have a schematic of the pump with the plunger in question? Just curious on what it looks like and where its located. When they break, does it ruin the whole head of the pump? I resealed the roosamaster on the Case so I have a decent idea whats going on with one.
I guess I'm its last shot in life as the head of the estate said if it couldnt be fixed it might be scrapped.
Whats the general opinion on these tractors? If they dont want to put the money in it I might try to buy it.
Neil Grant
12-04-2012 18:44:04
 Re: Cockshutt 570 DIesel, Injection pump problems in reply to Mikefromcny, 12-03-2012 18:47:51
Opinion of the 570? Probably the second best Cockshutt, 570 Super the best. Good power to weight, bullet proof drivetrain if it I maintained at all. Easy to shift gears. Solid built machine good for lots of hours. Downsides would be expensive Hercules engine parts, power steering was period correct in being not the best (gremmer) similar to Oliver's of the period. ditto for the seat.
I have spent many hours on a 570 Super.
Regards
Neil
