Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Cletrac E-62
[Return to Forum]
John in palmyra
12-02-2012 17:14:51
75.196.130.252
I just picked up a Cletrac E-62. What does the E-62 stand for and how rare is the model?
[Reply]   [No Email]
Bret4207
12-03-2012 15:35:55
64.19.90.196
 Re: Cletrac E-62 in reply to John in palmyra, 12-02-2012 17:14:51
Well, call me an optimist, but if you can get the tractor running and the tranny still puts power to the drive sprocket, I bet the tracks will loosen up just by running it back and forth a bit. You'd be surprised the way they'll break free. If they stick in a humped up fashion, smack it with a heavy hammer of 12-16 lbs if you can find one. Drain oil and diesel sprayed in the pin and bushing area can help.
Friend of mine took a D4 that had been sitting in the ocean for several years and broke the tracks loose just dragging it up and down the beach there in Alaska with a D7. I now own the tracks and while you can see where the salt water messed with them, the pins and bushings are still tight.
[Reply]  [No Email]
J. Schwiebert
12-02-2012 17:40:42
209.143.33.150
E is the model of the crawler. 62 is the width of the tracks center to center. The model was made in several different widths some wider than yours. Is yours what is known as a "streamlined" model or is it older than that? World War 2 ended production of the model because the factory + Hercules was ramping up for war production. Depending on the age of yours there will be 2 places to look for the serial number. Post that and we can tell you more. The Rare model E is the ED-2 which means it is powered witha Buda diesel instead of a Hercules such as found in the Ed models. More questions?
[Reply]  [No Email]
John in palmyra
12-02-2012 17:58:12
75.196.130.252
 Re: Cletrac E-62 in reply to J. Schwiebert, 12-02-2012 17:40:42
Thanks alot for that info. I have asked many people what the 62 ment and you"re the first that knew. I checked the Serial number and found out that it is a 1937 model. I bought it at an auction where the owner had died. It is estimated that it has been sitting for 20 to 30 years. The motor is free although I haven"t tried to fire it yet. I was going to change the oil and put some atf in the cylinders first. It has the Hercules motor in it. The tracks are froze up and won"t turn so I have my work cut out for me. Once again thanks for the info.
[Reply]  [No Email]
RussUPpswrd
12-03-2012 15:20:50
184.20.5.73
 Re: Cletrac E-62 in reply to John in palmyra, 12-02-2012 17:58:12
Spray cylinders with PB Blaster and add a tablespoon of Marvel Mystery oil in each cylinder. Don't add anti-freeze to any of the cylinders. Secure the crawler to a large tree
with a strong chain or cable. Jack up one side of the crawler tracks. Make sure the xmsn is in neutral. Bring in a very large tractor, crawler or huge bucket loader. Fasten the E-62 via an opened cleat to your monster puller. Drench the track pins with PB Blaster or WD-40 or other spray lube type. If your monster puller can grip black top or concrete surface even better.
If the track starts rotating celebrate with cold beers. Not many have loosened 30 years of rust.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
