Three Point Cast Iron Part Needed
Iowa Jim
I twas backing up our sprayer this summer and had the three point in the wrong position, when I turned short I snapped the clevis where the lower pin of the three point arm goes. Do any of you know where i could get one to replace mine?
Is this the piece you need? What model Oliver?
http://www.ebay.com/itm/oliver-1750-1755-1800-1850-1850-1900-1950-1955-farm-tractor-3rd-link-bracket-/271103092886?pt=LH_DefaultDomain_0&hash=item3f1f00e896
(quoted from post at 19:21:56 11/17/12) Is this the piece you need? What model Oliver?
Nope that is for the top link.
Are you talking the claw that closes over the ball on the implement side? Those should be available from a dealer, or any junk yard that has Olivers. We've had a few break in the past. Nothing in recent years.
Donovan from Wisconsin
(quoted from post at 19:13:26 11/17/12) I twas backing up our sprayer this summer and had the three point in the wrong position, when I turned short I snapped the clevis where the lower pin of the three point arm goes. Do any of you know where i could get one to replace mine?
I don't think that part is cast iron. Probably cast steel and is weldable if you still have the pieces.
