TractorLinks.com
Show Parts for Model:
Re: white 2-150 transmission lube question
J. Schwiebert
11-25-2012 08:59:58
Can you run just the engine (block the clutch petal down)? Why do you need to remove the long shaft? Also make sure you keep the O/U unit in low range and the transmission in low range. Have the top shaft and all the transmission gears turn as slow as possiable.
buzzinduzzin
11-25-2012 18:57:28
 Re: white 2-150 transmission lube question in reply to J. Schwiebert, 11-25-2012 08:59:58
thank you for the answer! I didnt think about blocking the pedal! duh. Doing a engine swap & I dont have the hyd. cooler/radiator details figured out yet. I thought leaving the long shaft out would be easiest way to disable the most systems. The over under guts have been replaced with a one piece shaft. the engine I am using has been sitting a while so am wanting to hear it run before building more stuff around it
