TractorLinks.com
Show Parts for Model:
Re: 88governor
J. Schwiebert
11-22-2012 07:29:42
How much wear is on the gear? Before the days of the new style bushings we had some tractors with high hours running around that had two of the K 289 thrust washers to take up some of that wear. How much wear is on the pivot edge of the weights and in the pin area? Probably 90% of the governor arms need to have the holes brazed shut and new holes drilled in them because of wear in that area as well. The same is true for worn linkage. Is this a farm tractor or a pulling tractor? If using for farm work you need 19 active coils on your governor spring
d88
11-22-2012 07:43:02
 Re: 88governor in reply to J. Schwiebert, 11-22-2012 07:29:42
there was no thrust washer.i have added 2 thrust washers on 77 that had bad wear on block worked fine. its a 451 ci puller
