Hydraulic Power Beyond Instructions
B A Star
   To those that are wanting to use the tractor's hydrualic system for a remote valve, mainly for loaders.
   Here is the Service Bulletin for plumbing the tractor's hydraulic system for Power Beyond.  1550, 1650, 1555, 1655 and 2-70 all have the same hydraulic system. 1750, 1850 & 1950 are the same, 55 series have closed center systems.
   Remember you must have an open center valve on the loader.
some times you have to use some heat on those plugs after 40 or 50 years. Ive done a few and had good and bad luck with removing the pipe plugs.
Do you or anyone else have the Service Buillton (sp?) on power beyond for 88/super 88/880 tractors? Also any information for a crankshaft driven hydraulic pump for the same models? Armand
