Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: 880 clutch
[Show Entire Topic]  [Return to Forum]
J. Schwiebert
11-21-2012 16:25:13
209.143.33.150
You do no drain any oil! You pull thr long shaft, not the shaft you hook the implement too.
[Reply]   [No Email]
brian stanek
11-21-2012 19:00:55
207.102.37.166
 Re: 880 clutch in reply to J. Schwiebert, 11-21-2012 16:25:13
thanks again for you info yes this aft. i finally figuired it out and got everthing apart. do you know if the pressure plate fingers can be set up for more movement or if it is just a new one needed?
[Reply]  [No Email]
J. Schwiebert
11-22-2012 04:29:10
209.143.33.150
 Re: 880 clutch in reply to brian stanek, 11-21-2012 19:00:55
As the clutch wears the levers move back. So the clutch releases sooner. Also the clutch disk is thinner because of wear. Since your clutch did not release, I would say the pilot bearing has failed causing the shaft to keep rotating. I also was not too clear on your comment about problems shifting from one range to the other range. Does the transmission imput shaft have any endplay? If so repair it while the engine is out.
[Reply]  [No Email]
brian stanek
11-22-2012 12:15:38
207.102.37.33
 Re: 880 clutch in reply to J. Schwiebert, 11-22-2012 04:29:10
well its all apart now. actually the pilot bearing was good, but for $7 will get a new one. there is still some flywheel side paint markings on the clutch, it seems quite good. lots of wear on the pressure plate fingers. definately needs a new pressure plate and will also get a new throught bearing. i did not chech tranny input shaft end play. thanks for all the help.
[Reply]  [No Email]
brian stanek
11-22-2012 12:17:53
207.102.37.33
 Re: 880 clutch in reply to brian stanek, 11-22-2012 12:15:38
i forgot tp tell you the sleeve the throught bearing slides on seems to have the end collar worn off. the sleeve is about 6 inchs or so.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
