77 governor/ will a 88 model work?
Troy Benner
New User
found a problem with my super 77 governor, thrust bearing went and let the weights throw out to far for to long and eventually the pin for the one weight broke and the bushing fell out and now the weight is egg shaped, my guess is just find another governor, question is will a 88 waukesha motor governor fit a super 77 6 cyl with a waukesha motor?
Yes, it will work, might have to readjust linkage..... I think Korves Oliver has gov. Rebuild parts....
thanks for the replies, I did talk to Korves, they have a used gov for $225. A little more than I wanted to spend plus another 67 for the bearing. I found a used on on ebay from an 88 hoping to get for less, says bearing and pins are all good.
Give Northeast Tractor Salvage in Nebraska a call and talk to Dennis or Jim, they should have one and can ship it to you. 1-800-747-2071
