Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Losing Hydraulic Fluid
J. Schwiebert
11-15-2012 03:16:08
Did you loose the fluid when (if) you blocked off the PTO? If you did not you need to drain the rear enf and pull the PTO and reseal the PTO clutch & brake. Those seals have been updated more than once.
UP Oliver
11-15-2012 05:26:00
 Re: Losing Hydraulic Fluid in reply to J. Schwiebert, 11-15-2012 03:16:08
I have to done anything back there.
When you say block off the PTO, are you talking about that little tube that goes from the hydraulic compartment to the PTO?
Would that be my first step, blocking off that tube?
Thanks
Bradwi
11-15-2012 18:46:11
 Re: Losing Hydraulic Fluid in reply to UP Oliver, 11-15-2012 05:26:00
yes block off the long one that runs up under the floor boards that is the pressure line to the pto control valve,if it cures your problem than you likely need a quad ring kit for the pto
UP Oliver
11-16-2012 05:33:49
 Re: Losing Hydraulic Fluid in reply to Bradwi, 11-15-2012 18:46:11
Thanks for the help. I'll block that off and see what happens.
Where do you get a quad ring kit?
Is that a major project to take care of?
Thanks again.
J. Schwiebert
11-16-2012 05:52:37
 Re: Losing Hydraulic Fluid in reply to UP Oliver, 11-16-2012 05:33:49
Send me an e-mail.Make sure your phone number is on it. I lost all my e-mail type information a few weks ago.
Copyright © 1997-2015 Yesterday's Tractor Co.
