I looked at what I am pretty sure is a super 66 today.I could not see all of the serial numbers this is what I could see 66-0148 which I think is the spec number. Under that all I could see was O118. I did get the number off side of block which was 180220 The frame does have flat side blocks on it also flat block on front of frame. hydrolic unit did have handles that came out from side of unit that went up and made a 90 degree turn, instead of from top of unit. Anybody have any idea what year it might be.
Don't think it is a Super 66. Should have a 7 or 8 digi serial number with the last 3 numbers being 603 or 606. Also it has a Fleetline group 2 hydraulic system
There is a collector near me that bought a "Super 66" kind of like you describe, Super front frame, serial number is kind of like yours. He said why does that serial number not show up? Because it is a Fleetline 66, The engine gave it away. Fleetline engine, rear end + serial number, Super front frame.
OK, I went back this evening and was able to get the full serial number. 3509287 which by my book tells me it is a 1953 66 fleetline tractor.I guess it had a super front end put on it at sometime. The engine number is G3923694. Is this a fleetline 66 engine or a Super 66 engine? Also has the number 180220 cast into the left side of block.
